Isolating ASUS tablet speed deficiency on 5GHz
username0475
I'm on Merlin's 384.6.
Everything running great except my ASUS 3S 10 Tab is giving 10% of the download speed vs. my other 5GHz clients.
I confirmed that the tablet was giving better performance in the 100+ range when I was out of town @ a hotel using their WiFi this weekend.
What can I check on the router side to narrow down this issue?
Try using a lower channel number (like 36). My own Zenpad 3S was highly unstable on wifi while using channel 157. Crappy Mediatek chipset.
I was originally on the 161 channel - so I tried 48 & then 36 but no improvements.
Will try all the channels...Should I reboot router after each change?
No need to, if 48 has issues, then 36 would most likely be identical. The important test was to use a channel from that lower band.
No need to reboot, the wireless subsystem restarts itself when you change channels.
Try all the usual recommendations then - disabling beamforming, airtime fairness, etc...
Gotcha. Thanks will try.
I actually do like this tab a lot. Only the 5GHz speed is the anomaly.
Fairly happy with my Zenpad 3S 8 myself. I preferred the 4:3 format since I use it a lot for ebook reading. CPU is fairly speedy, my main issue is the crappy wifi it has (even my older Nexus 9 had dual stream support, this one is single stream only). And that its fingerprint reader died after about three weeks, had to RMA it to Asus.
