I've had some problems with my DSL AX82U. So now need to change my setup so I use my isp device as the modem and the asus as my router. So after some advice.
On the sky hub:
Just need to check am doing correctly. On my sky hub I disable wifi, disable dchp and assign it a ip address (192.168.1.2) for access also disable firewall and connect cable to port 1?
On the asus router
Connect cable to WAN port.
Make sure dchp is in the above range. Done?
On the sky hub:
On the asus router
