Issue on WiFi connection speed
Massi1234
Hi - I have an Asus RT-AX88U and my Windows Surface Laptop 2 with a 2x2 AC wifi card only connects to it at 173Mbps...
I thought it would have reached into the 1000Mbps
I wonder if I set the 5 Ghz wrong ...
Currently wireless more id n/AC/AX mixed
801.11ax HE frame support is enabled
Channel Bandwifdht is 20/40/80/160
Control channel Auto
Auto select channel including DFS is disabled
Is there any other setting i should change to get the 2x2 card to connect to the router at a higher speed?
Sent from my SM-G973F using Tapatalk
