pixelserv Issue - pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/...
sentinelvdx
Hi Guys,
I've recently checked my syslog and it's flooded with these statements:
Sep 13 20:42:19 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.global.ssl.fastly.net
Sep 13 20:42:22 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.global.ssl.fastly.net
Sep 13 21:36:56 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.tt.omtrdc.net
Sep 13 21:36:59 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.tt.omtrdc.net
Sep 13 21:37:00 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.tt.omtrdc.net
Sep 13 21:37:02 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.weborama.fr
Sep 13 21:37:06 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.weborama.fr
Sep 13 21:37:07 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.weborama.fr
Sep 13 21:37:09 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.weborama.fr
Sep 13 21:37:15 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.tt.omtrdc.net
Sep 13 21:37:17 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.tt.omtrdc.net
Sep 13 21:41:36 pixelserv-tls[2321]: generate_cert: failed to open file for write: /opt/var/cache/pixelserv/_.display.io
Any idea what could be causing it and steps I could try to solve it?
Thanks!
Hi Guys,
Thanks!
Noticed the same type of errors late last week. Went to the CLI and AMTM. Force updated all scripts which I used and the message went away.
I'm going to try that. I'll update later. Thanks!
Diversion has a function to clear all domain certificates for pixelserv-tls in ep. Do that and see if the errors persist.
That one solved it. Thanks!!
