[Issue RT-AC66U] Upnp Portmapper fail
secure mode is enabled you can only map ports to your own ip
there's an nvram value
but no way of setting it in the web interface
i always set secure mode disalbed on every firmware i compile
you can find it in the source here
nvram_get_int("upnp_secure") ? "yes" : "no", // secure_mode (only forward to self)
https://github.com/RMerl/asuswrt-merlin/blob/master/release/src/router/rc/services.c
you could also i suppose set the nvram value via telnet
try
nvram set upnp_secure=no
nvram commit
reboot
it may hold or not..
try
nvram commit
reboot
Thanks I got the same solution from Merlin and it appears to work fine although I didn't reboot. I just restarted the upnp service
service restart_upnp
That'll work for me even if I have to reset it after a reboot.
