I have an issue with open vpn client connection, full log below. Can someone advice what is wrong here? Merlin 386.2_6 and AX88u here.
Jul 16 07:44:35 ovpn-client1[19288]: OpenVPN 2.5.2 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jun 6 2021
Jul 16 07:44:35 ovpn-client1[19288]: library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.08
Jul 16 07:44:35 ovpn-client1[19289]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jul 16 07:44:35 ovpn-client1[19289]: Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Jul 16 07:44:35 ovpn-client1[19289]: Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Jul 16 07:44:35 ovpn-client1[19289]: Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Jul 16 07:44:35 ovpn-client1[19289]: Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Jul 16 07:44:35 ovpn-client1[19289]: TCP/UDP: Preserving recently used remote address: [AF_INET]x.x.x.x:1194
Jul 16 07:44:35 ovpn-client1[19289]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Jul 16 07:44:35 ovpn-client1[19289]: UDP link local: (not bound)
Jul 16 07:44:35 ovpn-client1[19289]: UDP link remote: [AF_INET]x.x.x.x:1194
Jul 16 07:44:35 ovpn-client1[19289]: TLS: Initial packet from [AF_INET]x.x.x.x:1194, sid=ffdd5ad2 b13136d4
Jul 16 07:44:35 ovpn-client1[19289]: VERIFY OK: depth=1, CN=ChangeMe
Jul 16 07:44:35 ovpn-client1[19289]: VERIFY KU OK
Jul 16 07:44:35 ovpn-client1[19289]: Validating certificate extended key usage
Jul 16 07:44:35 ovpn-client1[19289]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Jul 16 07:44:35 ovpn-client1[19289]: VERIFY EKU OK
Jul 16 07:44:35 ovpn-client1[19289]: VERIFY OK: depth=0, CN=server
Jul 16 07:44:35 ovpn-client1[19289]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256
Jul 16 07:44:35 ovpn-client1[19289]: [server] Peer Connection Initiated with [AF_INET]x.x.x.x:1194
Jul 16 07:44:36 ovpn-client1[19289]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Jul 16 07:44:36 ovpn-client1[19289]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 ipv6 bypass-dhcp,dhcp-option DNS 172.26.0.2,tun-ipv6,route-gateway 10.8.0.1,topology subnet,ping 10,ping-restart 120,ifconfig-ipv6 fddd:1194:1194:1194::1000/64 fddd:1194:1194:1194::1,ifconfig 10.8.0.2 255.255.255.0,peer-id 0,cipher AES-256-GCM'
Jul 16 07:44:36 ovpn-client1[19289]: OPTIONS IMPORT: timers and/or timeouts modified
Jul 16 07:44:36 ovpn-client1[19289]: OPTIONS IMPORT: --ifconfig/up options modified
Jul 16 07:44:36 ovpn-client1[19289]: OPTIONS IMPORT: route options modified
Jul 16 07:44:36 ovpn-client1[19289]: OPTIONS IMPORT: route-related options modified
Jul 16 07:44:36 ovpn-client1[19289]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Jul 16 07:44:36 ovpn-client1[19289]: OPTIONS IMPORT: peer-id set
Jul 16 07:44:36 ovpn-client1[19289]: OPTIONS IMPORT: adjusting link_mtu to 1624
Jul 16 07:44:36 ovpn-client1[19289]: OPTIONS IMPORT: data channel crypto options modified
Jul 16 07:44:36 ovpn-client1[19289]: Data Channel: using negotiated cipher 'AES-256-GCM'
Jul 16 07:44:36 ovpn-client1[19289]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Jul 16 07:44:36 ovpn-client1[19289]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Jul 16 07:44:36 ovpn-client1[19289]: GDG6: remote_host_ipv6=n/a
Jul 16 07:44:36 ovpn-client1[19289]: net_route_v6_best_gw query: dst ::
Jul 16 07:44:36 ovpn-client1[19289]: net_route_v6_best_gw result: via :: dev lo
Jul 16 07:44:36 ovpn-client1[19289]: TUN/TAP device tun11 opened
Jul 16 07:44:36 ovpn-client1[19289]: TUN/TAP TX queue length set to 1000
Jul 16 07:44:36 ovpn-client1[19289]: /usr/sbin/ip link set dev tun11 up mtu 1500
Jul 16 07:44:36 ovpn-client1[19289]: /usr/sbin/ip addr add dev tun11 10.8.0.2/24
Jul 16 07:44:36 ovpn-client1[19289]: Linux ip addr add failed: external program exited with error status: 2
Jul 16 07:44:36 ovpn-client1[19289]: Exiting due to fatal error
