alexpatcas
So i have this HP Procurve 2824 (J4903A) and for the most part it's awesome.
Now on every computer in the house i have dual gigabit nics. These are intel server pro mt nics. Dual ports.
I can never copy anything over the network from one computer to another and use more the 50% of the bandwidth. I have jumbo frames enabled. But anything i try to copy only uses 50% of the bandwidth, effectively limiting me to 1 gb/s.
Any help would be great. Thank you in advance
time timezone -300
web-management ssl
no telnet-server
interface 1
lacp Active
exit
interface 2
lacp Active
exit
interface 3
lacp Active
exit
interface 4
lacp Active
exit
interface 5
lacp Active
exit
interface 6
lacp Active
exit
interface 7
disable
lacp Active
exit
interface 8
disable
lacp Active
exit
interface 9
disable
lacp Active
exit
interface 10
disable
lacp Active
exit
interface 11
disable
lacp Active
exit
interface 12
disable
lacp Active
exit
interface 13
disable
lacp Active
exit
interface 14
disable
lacp Active
exit
interface 15
disable
lacp Active
exit
interface 16
disable
lacp Active
exit
interface 17
lacp Active
exit
interface 18
lacp Active
exit
interface 19
lacp Active
exit
interface 20
lacp Active
exit
interface 22
disable
exit
interface 23
disable
exit
interface 24
disable
exit
ip default-gateway 10.10.0.1
sntp server 10.10.0.1
timesync sntp
sntp unicast
snmp-server community "Home" Unrestricted
vlan 1
name "Home"
untagged 1-24
ip address 10.10.0.200 255.255.255.0
jumbo
exit
vlan 100
name "Management"
exit
fault-finder bad-driver sensitivity high
fault-finder bad-transceiver sensitivity high
fault-finder bad-cable sensitivity high
fault-finder too-long-cable sensitivity high
fault-finder over-bandwidth sensitivity high
fault-finder broadcast-storm sensitivity high
fault-finder loss-of-link sensitivity high
fault-finder duplex-mismatch-HDx sensitivity high
fault-finder duplex-mismatch-FDx sensitivity high
spanning-tree
ip ssh
password manager
