YazFi Issues with Yazfi starting DHCP
Chewie420
Having an issue with Yazfi DHCP Start/End setting. I have configured my SSID in Yazfi GUI to have an IP of 191.168.1.0 and have starting IP of 55 and ending in 155.
My devices are getting IPs such as 192.168.1.3. I was hoping to have them be within the range I had set. Can anyone assist with what is wrong?
Have you rebooted the various YazFi guest devices in addition to rebooting the router?
It doesn't hurt to double check the YazFi CLI option #3 (then select either Nano or Vi) and check the values for DHCPSTART and DHCPEND. Check those values for each of the guest WiFi entries. Also double check that IPADDR for each WiFi segment is unique.
Worst comes to worst, just assign static IP addresses to the YazFi guest WiFi clients.
https://github.com/jackyaz/YazFi/wi...e-and-ARP-records#a-note-on-dhcp-reservations
Or see my post here where setting a YazFi static IP is explained.
https://www.snbforums.com/threads/y...inc-ssid-vpn-client.45924/page-32#post-473403
On a side note, at this time AIMesh Nodes are not supported by YazFi.
First I want to start out by saying, I commend Bennor for attempting to troubleshoot with the limited information provided by the OP. I feel like @bennor covered the most common ailments.
To @Chewie420 , can you please start off by providing what the IP information of the parent network is (your primary network)? What is your main network IP range? Are you using IP ranges on any of the other guest networks, and if so, what are they? Also, feel free to share more information in regards to your primary network, keep out or redact any personals though. I am attempting to replicate your conditions.
