DarkPokemon2948
So i got an Asus TUF AX3000 V2 and i dont know if there is support for the V2 version. Can somebody tell me please?
If it's not on this list it's not supported:So i got an Asus TUF AX3000 V2 and i dont know if there is support for the V2 version. Can somebody tell me please?
https://gnuton.github.io/asuswrt-merlin.ng/ in listSo i got an Asus TUF AX3000 V2 and i dont know if there is support for the V2 version. Can somebody tell me please?
No, don't.But are you sure that i can put the V1 firmware at V2 Hardware?
(TUF-AX3000 V2)
Note: There are two versions of the TUF-AX3000, the OP has the newer V2 version:
If you try and install an incompatible firmware through the "normal" methods it will be rejected. However, if you bypass these checks and try and write the firmware directly to the flash memory you could indeed end up with a brick.Generally it IS NOT a good idea to flash firmware for one model to that model's V2 or later Vx version unless the firmware developer indicates its OK to do so. Doing so could brick, possibly permanently, the router. In this case the AX3000 V2 has some different hardware (processor, 2.5GB port, etc.) and features than the the AX3000 version.
It has excellent price of 80€
Welcome To SNBForums
