Java on RT-AC87U?
NoNameHD
Inspired by this post I thought I'd try to set up my router as an OpenHAB server. For OpenHAB to run Java is required, which I tried to set up by downloading zulu-jdk-8 for the arm-32bit platform with soft floating (as far as I am aware the router does not support hard floating). I extracted the file to /opt and ran the following commands:
# cd jdk8/bin
# pwd
/opt/jdk8/bin
# ./java -version
-sh: ./java: not found
# /opt/lib/ld-linux.so.3 --library-path /opt/lib ./java -version
Error: could not find libjava.so
Error: Could not find Java SE Runtime Environment.
Is it even possible to run Java on an RT-AC87U? If so what did I do wrong?
