jffs lifespan affected by reads?
BassKozz
I know the jffs partition shouldn't be used for a large amount of writes because it will cause wear on the flash memory, but do reads affect the flash memory's lifetime?
I have a 3.4K script in the jffs partition that runs every minute (via cron). Since this script gets called every minute of every day, I know those reads can add up. My question is, should I be worried about that?
I suppose I can have the init-start script copy my script that gets called every minute to /tmp (ram) and run it from there, but I don't know if I should be worried about it or not.
Thanks in advance,
-BassKozz
Reading is safe. The whole firmware is running from that same flash anyway.
