Miguel Santa
Does the ASUS RT AC5300 support Jumbo Frame packets? If so how do I enable them?
Jumbo frames are not needed with today's Ethernet adapters. Don't bother.
But on the router (well, John's fork - don't know about Merlin's latest) there is the option at LAN > Switch Control to "Enable Jumbo Frame", which is disabled by default.Some ethernet drivers - they may disable Jumbo, so that's the place to look - not in the Router...
# robocfg showports
Switch: enabled
Port 0: 1000FD enabled stp: none vlan: 2 jumbo: off mac: 00:01:5c:7a:fa:47
Port 1: 1000FD enabled stp: none vlan: 1 jumbo: off mac: a0:b3:cc:df:1f:cb
Port 2: 100FD enabled stp: none vlan: 1 jumbo: off mac: 40:b8:9a:b4:3d:dd
Port 3: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 4: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 94:de:80:c5:79:52
Port 8: DOWN enabled stp: none vlan: 2 jumbo: off mac: 00:00:00:00:00:00
Maybe one day, if I'm really bored. But with only 2 wired devices I doubt that I be able the measure the difference.So turn it on and see...
All Asus routers support Jumbo frames.
Oh I know bro. I'm just saying that all Asus routers since the N66U support Jumbo frames.As long as the path between two points supports it - this is MTU path discovery - and it works very well...
Thread starter | Title | Forum | Replies | Date |
F | Inbound packets are not captured | ASUS AC Routers & Adapters (Wi-Fi 5) | 0 |
Welcome To SNBForums
