Kamoj Kamoj Addon 5.5 b47 for Netgear R7800/R8900/R9000 with Voxel FW
kamoj
THIS IS A BETA VERSION
Bug reports and questions can be reported in this thread.
This add-on must be used with Voxel Firmware.
It can be used with the Netgear routers: R7800 / R8900 / R9000
Add-on features in short:
Extended information about the router, settings, firmware etc. Examples:
  • Router Temperatures
  • CPU Load Total (per core)
  • Memory Usage
  • Disk Usage
  • Connected Devices
  • WiFi Speed, Power and RSSI
  • Latest Available Firmware indication
  • Access to Hidden Menus
New router functionality. Examples:
  • Adguard Home
  • Aegis
  • OpenVPN Client handling
  • Wireguard Client handling
  • Bypassing OpenVPN Client tunnel for specific clients
  • DNS Encryption Privacy (Adguard/DNSCrypt proxy 2/Stubby)
  • Ad-Blocking, Malware-blocking etc
  • Flash-memory health status
  • Time synch without NTP
  • HDD Spin down (sleep)
  • Wake-On-LAN
  • Cron Jobs
  • Congestion Control
  • Network Parameter Options
  • WiFi Devices Info
  • Top command
  • Log-files
  • Show all devices in "Attached Devices" and "Access Control" - even when idle/sleeping.
  • Supervision of the WAN connection, and make Power LED amber if no connection.
  • Speed test (also available as command line command)
Pre-requisites:
  • Voxel Firmware installed on your router (preferable latest version):
    https://voxel-firmware.com/Downloads/Voxel/html/index.html
  • A telnet client program
  • Hold down the Windows Key, then press the “R“ key.
    The Run dialog box appears. In the Open: window, type:
    dism /online /Enable-Feature /FeatureName:TelnetClient
    Click OK
  • Internet connection (To download the add-on installation file)
How to install:
#1. Logon (From your web-browser):
http://www.routerlogin.net
#2. Make a backup of current settings (Not needed, but easy done):
Advanced, Administration, Backup Settings, Back Up, Save
#3. Enable Telnet:
http://www.routerlogin.net/debug.htm
Check (Set a tick in the box for) "Enable Telnet". (No apply needed)
#4. Login to the router using telnet:
cmd
Click OK.
telnet www.routerlogin.net
The password is the same as from the normal router login page http://routerlogin.net
#5. Download and Install the add-on:
curl -fkso- https://www.voxel-firmware.com/Downloads/Voxel/Kamoj/.Download/addon_install.sh | sh -s
#6. To see the result, open your web-browser and go to your router:
http://www.routerlogin.net/index.htm and click the ADVANCED tab.
Here you will find the new options:
  • Kamoj Menu
  • Hidden Menus
DONE!
Removal of all Kamoj add-on nvram setings:
Login to the router using telnet and issue these commands:
nvram show | awk -F= '/^kamoj/ {print $1}' | xargs -n1 nvram unset
nvram commit
Uninstall/Removal of the Kamoj add-on code:
/bin/opkg remove kamoj-addon
reboot
Content:
Content, Information headers:
  • Router Information
  • System Version Information
  • Firmware Version Information
  • QoS Information
  • System Uptime
  • CPU Frequencies and Governors
  • CPU Load Total (processes) (per core)
  • CPU Temperature
  • Fan speed
  • Network SubSystem Accelerator
  • RAM Memory Usage (Used/Total)
  • Flash Usage (Used/Total)
  • Disk Usage (Used/Total)
  • NVRAM Usage (Used/Total)
  • Temperatures CPU / WiFi0 / WiFi1
  • Temperatures 802.11ad Radio / Antenna
  • 5G WiFi0 (ath0)
  • 5G WiFi0 Temperature
  • 2G WiFi1 (ath1)
  • 2G WiFi1 Temperature
  • 802.11ad 60 GHz (wlan0)
  • 60 GHz 802.11ad Radio Temperature
  • 60 GHz 802.11ad Antennas Temperature
  • VPN Clients Available
  • VPN Client Name
  • VPN Client Status
  • VPN Client Speed
  • DNSCrypt v2 Servers
  • Stubby DNS Servers
  • Adguard Home DNS Servers
  • Iptables information
  • Congestion Control; Current ( Available )
  • Startup time and NTP status
  • DNS status
  • Internet connection status
  • Network Session (Active/Total)
  • WAN Information
  • WAN Speed
  • Port Status
  • eSATA Device
  • USB Device
To @Voxel for all help and support he's given to many people during long time.
To everyone active in the forum, especially those that have liked or commented my add-on.
/Kamoj
Release Note / Changes:
See also:
Kamoj Add-on at Voxel's site
(Download and read these files to learn more about the addon and the Netgear routers).
Previous add-on version information can be found here:
https://www.snbforums.com/threads/k...800-x4s-and-r9000-x10-temperatures-a-o.55063/
https://www.snbforums.com/threads/k...800-x4s-and-r9000-x10-temperatures-a-o.49907/
https://www.snbforums.com/threads/k...on-for-netgear-r7800-x4s-and-r9000-x10.48965/
https://www.snbforums.com/threads/k...tgear-r7800-x4s-running-voxel-firmware.48139/
