kernel: jffs2_flush_wbuf(): Write failed with -5
faria
Hi Guys,
After upgrading to my rt-acc66u Firmware:374.41 (Merlin build) i have noticed the following errors in the logs :
Apr 27 20:39:05 kernel: jffs2_flush_wbuf(): Write failed with -5
Apr 27 20:39:05 kernel: Write of 1161 bytes at 0x01098e70 failed. returned -5, retlen 0
Apr 27 20:39:05 kernel: Not marking the space at 0x01098e70 as dirty because the flash driver returned retlen zero
Apr 27 20:39:05 kernel: Write of 1161 bytes at 0x010607e0 failed. returned -5, retlen 0
Apr 27 20:39:05 kernel: Not marking the space at 0x010607e0 as dirty because the flash driver returned retlen zero
This only happens at odd reboots.
So i ask, should i be concerned?
Attached to the drive i have a 1TB drive with ext3 file system.
Thanks.
Hello All!
I've just came into this issue... accidentally over Samba my sdb1 (EXT3 HDD) was not reachable and sda1 was very slow.
I typed: watch 'dmesg | tail -20'
- to see what happens if I reconnect my sdb1, but then I saw the following
Recovery of wbuf succeeded to 01020000
Write of 1401 bytes at 0x00a795d8 failed. returned -5, retlen 0
Not marking the space at 0x00a795d8 as dirty because the flash driver returned retlen zero
Recovery of wbuf succeeded to 01000000
Write of 1487 bytes at 0x01031680 failed. returned -5, retlen 0
Not marking the space at 0x01031680 as dirty because the flash driver returned retlen zero
I had a e2fsck run on my sda1, which returned with no error.
Something is wrong with the jffs partition? Or what? I'm getting angry with my choice with ASUS... :(
