I recently copied a bunch of mp3 files to the USB drive mounted on my AX3000. I'm running Merlin 386.3_2. I'm getting recurring errors like this one, which seem to have something to with the OS not liking characters in some of the filenames:
Nov 1 12:31:10 kernel: tfat error (device sda1, pid 5063): exfat_ucstonls(): Unicode name contains characters that cannot be converted to character set utf8. Try using the mount option nls=utf8.
Nov 1 12:31:10 kernel: tfat warning (device sda1, pid 5063): fat_readdir(): Going to use short name because long Unicode name contains characters that cannot be converted to character set utf8 (error 84). Try using the mount option nls=utf8.
Nov 1 12:31:10 kernel: tfat error (device sda1, pid 5063): fat_lookup(): Failed to convert long name from Unicode to character set utf8 (error 84). Try using the mount option nls=utf8.
Nov 1 12:31:31 kernel: tfat error (device sda1, pid 5064): exfat_ucstonls(): Unicode name contains characters that cannot be converted to character set utf8. Try using the mount option nls=utf8.
Nov 1 12:31:31 kernel: tfat warning (device sda1, pid 5064): fat_readdir(): Going to use short name because long Unicode name contains characters that cannot be converted to character set utf8 (error 84). Try using the mount option nls=utf8.
Nov 1 12:31:31 kernel: tfat error (device sda1, pid 5064): fat_lookup(): Failed to convert long name from Unicode to character set utf8 (error 84). Try using the mount option nls=utf8.
I'm not sure where the "mount option" mentioned above is set (or even if it's possible to set it within Merlin.) Is there somewhere this (and perhaps long filenames, since we are kind of beyond 8.3 naming nowadays hopefully) can be configured or some other way to fix?
