kernel: usb 1-1.1: reset high speed USB device using ehci_hcd
mberteotti
I'm getting this message quite often after a long period without any problem:
kernel: usb 1-1.1: reset high speed USB device using ehci_hcd and address 3
I've an USB 2.0 250gb HD with 2 partitions (sda1=swap and sda2=ext3) attached to my RT-N66U with 374.43 Merlin FW.
Drive seems to work correctly.
What's the problem?
Thanks.
I have the same, with a RT-N66U and Merlin 374.40 fw.
Do I need to worry? :confused: The drive seems to work as usual.
