SchneiderIS
I have a Asus AIMesh configuration setup with one AX88U and two AX86U's. My gig fibre comes into the detached garage where one router is placed as the primary. The other two routers are then setup as AIMesh nodes in the home with one on the main floor and the other in the basement. The home is a 1350 square foot bungalow on the main floor (close to the same in the basement but with lots of concrete and metal to cause interference). The home and the garage are well insulated so when devices connect to the garage router instead of the home one (even when the garage is an extra ~20 feet away as well as through the insulated walls) I am scratching my head. In some testing I am doing now it may very well be that the main floor router is failing making the following less of a concern, but still question that I would appreciate help with.
Current Layout:
The reason is primarily because I am having issues with WiFi devices not getting the performance from the Current Layout, and on several occasions finding my phone and tablet connecting to the garage AX88U unit. As noted, the garage unit is ~20 feet further away and goes through 2 insulated walls. The home unit is also more prone to being used for heavier WiFi traffic. In the past I was advised that the AX88U would be better in the garage as the AX86U had a stronger signal.
Would the Alternate Layout make more sense?
Current Layout:
- Primary router in the garage - AX88U
- Node in house on main floor - AX86U
- Node in house basement - AX86U
- Primary router in the garage - AX86U
- Node in house on main floor - AX88U
