LAN = 10mbps 5g = 450
Gabe63
I just installed my 66r from Best Buy. My LAN speed says 10mbps when my old DIR615 was 100 with the same computer and cables.
Internet speed test gives me 9.5mbps download on LAN and 28mbps wired. Any ideas what I should check?
Thank you
I would start with not using the same cables that you used for the dir-615. It most likely only came with a cat5 cable
I was getting 100mbps with those cables on my DIR 615. Now I am getting 10mbps with the new router and the same cables for my wired connection. They probably are CAT5, but they should do 100mbps.
What do you mean here? To me LAN is the wired connection...
Sorry, my wired connection is slower that my wireless. It is only showing a 10mbps transfer rate.
Double check the cables anyway. At least try another cable. The principle of elimination is one of the best fault finding methods.
