Let’s Encrypt issue on 384.19
Iwakan
Hi.
My Ac68u has been working with 384.19 without issues and very stable. Today, after a reboot, the browser showed me a certificate error (not possible because I’m using lets encrypt that was renewed two weeks ago) because the router UI now is using the default certificate.
Everithing is configured fine and the .le folder in /jffs is present with all files and certificates as usual. The only thing is that in WAN -> DDNS the status of the certificate is “Authorizing”. Seems a bug.
Rafael Viana
Hi.
Yes, here it is like that too! follow my solution!
Iwakan
Thank you Rafael.
So it’s confirmed it’s a bug and I’m not the only one. The problem with your workaround is that we lose the auto renewing capability.
Rafael Viana
Thank you Rafael.
Yes, !
L&LD
Part of the Furniture
Iwakan
@RMerlin LE code is open Or closed source? Do you think the fix could be implemented in the next release? Seems that Asus is aware of the bug and working in a quick fix.
Thank you.
L&LD
@Iwakan I'm sure RMerlin knew before we did. See the posts above yours. Everyone here knows too. :)
RMerlin
Asuswrt-Merlin dev
Thank you.
The fix will be included in the next code drop I get from Asus.
