Let's encrypt issue on latest 386.1 beta 2 (RT-AX86U)
dr_lucas
When trying to get a let's encrypt certificate, it keeps showing "Authorizing".
[EDITED: Let's encrypt issue is already listed as known]
Also, if I disable let's encrypt (set it to none), it generates a local certificate, but showing it was generated by and for 192.168.50.1, while my router is set on 192.168.1.1 and the network is on 192.168.1.x of course.
RMerlin
Asuswrt-Merlin dev
When running a beta firmware, it's a good idea to read the info posted in the Beta thread, especially the second post that lists all known issues. There are MANY posts there already about this.
L&LD
Part of the Furniture
192.168.50.1 isn't an issue. This is a configurable option.
RMerlin
Asuswrt-Merlin dev
Probably means the certificate was issued before you changed the IP, you will have to regenerate it.
blake444
I add myself to the conversation because I would like to ask, is it normal that after a factory reset the ddns section still shows the active certificate? and if so, what does its revocation entail?
L&LD
Format the JFFS partition on the next boot, make sure you hit 'Apply' at the bottom of the page before you reboot 3 times in the next 10 to 15 minutes (waiting between 5 to 10 minutes between each reboot).
RMerlin
Asuswrt-Merlin dev
RMerlin
Asuswrt-Merlin dev
Thanks. Unfortunately it didn't make any change.
Was broken in beta 2, a backup was restored on top of the newly generated certificate. Will be fixed in beta 3.
L&LD
On RMerlin 386.1 Beta 4, the new certificate is generated and valid on my RT-AX86U.
palint
Is this problem related somehow to a problem I get on my AC86U? I'm currently on 386_2.
I use succesfuly duckdns and I get error while trying to get LE certificate:
Verify error: Fetching [...] Timeout during connect (likely firewall problem)
Also on my RPi I can't get my certificate to work in docker - I get http connection to site which is supposed to have be certified..
Nighthawk
It works just fine on my AX86U firmware 386_2
