Limiting xbox 360 upload speed?
redpants
How do i go about doing this. If i enable QOS will that rule apply to both 2.4ghz and 5ghz? I just want to limit 2.4 ghz.
You could create a rule that only applied to your XBox's MAC address.
Cool. But when i go to User Specify Rule List under QOS theres no box to enter how much upload speed i would like the 360 to have?
i.e i want to make it so that the 360 only uploads @ 30kb/sec
Configure one of the classes with the desired up/download percentages, then assign all traffic from that MAC address to that specific class.
I think i got it right. But now my 5 ghz speed is suffering.. Why couldnt the interface just separate 2.4ghz and 5ghz? :/
Nov 13 09:11:45 kernel: HTB: quantum of class 10002 is big. Consider r2q change.
Nov 13 09:11:45 kernel: HTB: quantum of class 10060 is big. Consider r2q change.
Simply ignore that, it's just a kernel notice.
