linksys 160n
ronss
i found this firmware for my 160n linksys, this is dd-wrt firmware...
i mostly surf, email, download files...which firmware should i install, and what would be the advantage...
Filename Date Size
Micro Generic dd-wrt.v24_micro_generic.bin 2010-04-23 1,69 MB
Micro_OLSRD Generic dd-wrt.v24_micro_olsrd_generic.bin 2010-04-23 1,67 MB
Mini Generic dd-wrt.v24_mini_generic.bin 2010-04-23 2,88 MB
Standard Generic dd-wrt.v24_std_generic.bin 2010-04-23 3,57 MB
VPN Generic dd-wrt.v24_vpn_generic.bin 2010-04-23 3,64 MB
VoIP Generic dd-wrt.v24_voip_generic.bin 2010-04-23 3,60 MB
Latest DD-WRT Releases
Latest stable release
v24 SP1 (Build10020)
Latest development release
v24 preSP2 (Build1306
Stay with the stock Firmware if you're just doing basic Web, email, etc...
DD-WRT has its uses, but for most folks, it's overkill...
Filename Date Size
If that is all you do with your router. You don't gain anything from dd-wrt.
It may slow down a bit. Still if you want to try it out refer to dd-wrt forum and Wiki.
