25 devices connected to this router and I feel I don't need to use this feature.
Yes I think a standard QOS feature would have been a better choice.
Linksys Media Prioritization benefits people who really want high quality Netflix or other streaming media on devices regardless what others on the network are doing.
Standards Based Quality of Service is fully supported and automatic for the WRT1900ac - and from my review of the Attribute-Value Pairs, they're set pretty well...
Goes back to my earlier post - Media Prioritization as SmartWIFI calls it, this is traffic shaping - and this is also what some folks confuse with Quality of Service.
sfx
I wish a company would develop a new type of QOS that can dynamically throttle.
Currently QOS tends to reserve a percentage of bandwidth , so for example if you have a connection that can consistently provide exactly 50mbit/s upload and download, if you input exactly 50 into the QOS, then the speed will drop to around 48mbit/s or some other random speed that is close to what you entered but a little lower.
And then if you start playing with the QOS settings by entering higher speeds until it no longer drops the speed, you then get ineffective QOS.
Why cant someone make something similar to application priorities in windows task manager where regardless of priority, all applications have the ability to use the full speed of the CPU, but if a higher priority task requests CPU time, it will give it as much as it wants, leaving any excess for the low priority ones.
Why cant they just implement something like that for network priorities?
Qualcomm also has StreamBoost, which incorporates technology acquired along with BigFoot Networks.I wish a company would develop a new type of QOS that can dynamically throttle.
The issue I have is that it never works quite as smoothly as setting priorities for CPU time
Welcome To SNBForums
