lightaffaire
I activated remote logging on our gt-ax11000/rt-ax88u routers to our internal syslog server. Asus router/aimesh nodes are quite chatty so i created a logcheck filter file to remove crud from our logcheck reports.
Simply copy the attached file to /etc/logcheck/ignore.d.[server|workstation|<or-whatever-your-dir-is>/asuswifi and logcheck will do the rest for you.
Maybe you find it useful... maybe not... it is posted here as-is... you probably want to check each line before using it if you are security conscious.
Iain
Iain
