list of IPs?
Bamsefar
So I know from the syslog panel I have a client x.x.x.151 - however I can not see it under network map. Any idea how to figure out what it is?
Wireless Log has all wifi clients, DHCP page will show all DHCP allocated IPs.
Can you be more specific as to what you mean by "the syslog panel"? If it's an entry in Syslog, please post the exact entry.
"The syslog panel" = the "systemlogg selection on the WEB GUI interface, between "Administration" and "Networktools" (Well I have swedish words, so this is my guess what it is translated to in english).
The row reads:
May  4 21:19:38 kernel: DROP IN=br0 OUT=eth0 SRC=x.x.x.151 DST=46.137.90.12 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=61644 DF PROTO=TCP SPT=41266 DPT=9000 SEQ=299190930 ACK=0 WINDOW=5840 RES=0x00 SYN URGP=0 OPT (020405B40402080A0567BDDC0000000001030302)
And thanks for the tip (I simple don't know why I missed this): In the DHCP list of clients I find my missing client, x.x.x.151 - it's a SqueezeBox Touch mediaplayer... However I can not find it in my "Networkmap / View Client List" (that is the front web page when I log into my AC88, which with gui symbols shows connection to WWW-IP adress and security level, and my two USB drives - plus the number of clients and the "view list" button that shows all clients - however as I mentioned the x.x.x.151 is missing from this gui list.
Btw the DROP is because I only allow port 80/443/+ a few more to forward to internet. Port 9000, as in the row above, belongs to SqueezeServer - and I do not want that broadcast out on the internet...
Should be able to do an arp -a and find all clients that are being routed at the time - both wired and wireless...
This is a bit strange I would say:
When I look on the result after pushing the key "View List" (front gui web page), I get 5 wireless devices.
When I look under the Wireless Log page/tab, I will get 7 wireless devices.
If I enter "wl -i eth1 assoclist" and "wl -i eth2 assoclist" I list all wiresless connected devices, and that is 4 on 2.4GHz and 3 on 5GHz.
If I enter arp -a, I get 13 devices (some with static IP).
When I look under the page/tab DHCP leases, I will only find 7 and two of them are static.
So no matter how I do, I will get different results on some pages?
