Log File not being Updated
TonyK132
I just looked at my System Log and found that it has not been updated since 1-8-23. That's strange. So I rebooted but it is still not working. What do I need to do? How can I tell if this is just a display issue or if the log really is not being written? I have Disk Check loaded in amtm and when I looked at that log, it said my USB drive is OK.
Your sig says you are using Scribe, so check that that is working. Scribe may kill the internal syslogd and syslog-ng may fail to start.
Thanks, looks like that was the problem. I should have suspected that after I updated Entware last week. I thought to update unbound at that time but did not check if any other scripts needed to be updated.
