Any idea what the following in the system log means:
"received packet with own address as source address".
Update: Been doing a lot of research and can't find any answers. Seems to crop up on several router brands. Can I assume that the four LAN ports on the router are internally designated as eth0, eth1, eth2 and eth3? If so, since this message is always preceded by either eth1 or eth2 and i have upnp devices plugged into those LAN ports, could that be the cause/source and it is perfectly normal?
