log verbosity parameter in OpenVPN client
GSpock
Hello,
where can I find a description of the meaning of the misc. values (0 till 6) for this parameter ? (I assume 0 being nothing and 6 writing a bible) ?
Thx,
GS
--verb n
Set output verbosity to n (default=1). Each level shows all info from the previous levels. Level 3 is recommended if you want a good summary of what's happening without being swamped by output.​
0 -- No output except fatal errors.
1 to 4 -- Normal usage range.
5 -- Output R and W characters to the console for each packet read and write, uppercase is used for TCP/UDP packets and lowercase is used for TUN/TAP packets.
6 to 11 -- Debug info range (see errlevel.h for additional information on debug levels).​
