Logging in
You will get this if you are bypassing the router's DNS server, by using something like DNSFilter or a VPN client.
Yeah, it was the DNSFilter I had on. I turned it off, but I still couldn't log on with router.asus.com. So I did a restore and then reloaded a backup that didn't have the DNSFilter enabled and now everything works fine. Oh, it does work behind my VPN client. Thanks for the reply and the advice from you and skeal.
C How to turn **off** remote logging? Asuswrt-Merlin 3
D SysLog Logging Levels? Asuswrt-Merlin 1
