Long range wifi
ganja24
I am trying to get wifi in the park across my house distance 2000 ft, is there a outdoor wifi device that’s weatherproof rain, heat, extreme cold and can connect to my ASUS 68u mesh routers wired, device will be installed outside on roof or side of house that has long range wifi 2000 ft, is this possible? What device do I need to buy?
The problem you might have here is not the transmitting, it is the device (phone/laptop) sending the signal back.
use cellular or satellite to a base station/router that you carry with you. Your device wifi is not designed to transmit that far.
