looking for 3.0.0.4.270.26b
laracroftonline
Hello,
Who have this version for me?
Greetings,
Manuela
That version is old and filled with reported security holes. I would not run that if you value your network's safety.
Can be closed! A member has sended them to me!
https://mega.nz/#F!DRliyIiT!6DXrUancx9oiaQiNSJhPaA
If you are looking for a good alternative to that antiquated version then check out John9527's fork available right here in this forum. It is based on the 374.43 code, rated amongst the best-performing firmwares for the N66U. He also incorporates all security fixes so you know that you are safe. You should at least check it out.
