I'd appreciate advice about using 2 or 3 ac routers configured as access points, and using my cable provider's gateway as the DHCP router. They would be placed around the house and connect through my Ethernet cabling.
- Would there be a problem with interference among the multiple radios?
- Is this overkill for a medium sized house? I'm currently using a single "n" router and the signal is weak in other rooms. Maybe I should buy one first and see how it works?
