crashnburn
But they DO NOT fit my scenario as I do not have a SWEET SPOT. I have a Concrete Jungle around me.
I am not sure if this got across -
I'll add -
I am in a 2 level Condo made of Concrete in High Concrete Urban Asian City -
I am already using Mikrotik HapLite (Wireless N) as PRIMARY ROUTER and its PERFORMANCE is more than adequate (over Cat 6).
What I need 2 devices (1 for each level) to act as "Wireless AC" Access Points
(So 100$ for each is out of budget) -
To handle the Multiple "Smart Home Devices" that are crowding my airspace.
If I was to spend that much for each Wireless AC AP - I might as well get Ubiquiti AC APs.
Trying to not spend that far for now.
I do not mind buying several cheap Wireless AC routers devices and do some Wireless AC to Wired testing (do tell me how-to) on them to pick from that list and then have to get 2 of them.
Maybe some Tenda / Xiaomi / TP-Link or Chinese Routers as APs - maybe flash them DD-WRT or Open WRT if possible, and just to be "inexpensive AC AP slaves"
Also at this 69$ / sub 100 price would it make sense to there instead of 100$ WiFi 5 ones?
https://www.snbforums.com/threads/t...b-100-wi-fi-6-router.59719/page-2#post-522980
They used to be around 200$ when they launched. 100$ is a pretty reasonable price if you want a capable router. You can get cheaper 30-50$ models, however the performance will be in line with their pricing. The two models I mentioned are currently the sweet spot in terms of pricing vs performance.
I'll add -
Hoping to add 1/2 cheap routers as APs.
So, 40/50$ or something as cheap as 15/20$ just to act as good Wireless APs to a
Master Mikrotik HAPLite (N only) to handle Multi devices.
