Looking to replace AX-82u, need advice!
Cranjis Mcbasketball
Hi, I currently am on my 2nd AX-82 after the first one just died and the new one refuses to update and drops packets. I wanted to get something possibly better.
Currently these are the devices that are used on it:
  • 2 Phones
  • 2 PCs
  • Nintendo Switch
I do a lot of heavy gaming so I need something that will give a smooth experience without throttling, and something that doesn't use a phone to set up; I prefer something web-based for setting up my routers.
Budget is about $250
I greatly appreciate any help.
Most folks around will recommend you GT-AX6000 or RT-AX88U Pro models.
Both are very similar hardware, both Asuswrt-Merlin supported, GT is the "gaming version", RT is the newer "normal version". 🧐
Thanks for the reply. I was going to ask about Merlin next haha! Sounds good then, thank you!
If you don't need 2x 2.5GbE ports - more compact size model with similar hardware inside is RT-AX86U Pro.
Also popular around and also Asuswrt-Merlin supported. Usually can be found cheaper too. You're welcome.
Oh okay. Yeah I ended up ordering the AX88U Pro, I don't want to deal with those gamer-y functions in the BIOS lol and it's on sale. Thanks again!
