Beta Lyra MAP-AC2200 AiMesh 2.0 Beta?
David Sullivan
@ligeza -- Would you mind sharing firmware for the Lyra MAP-AC2200? I see in the original RC1/RC2 threads mention of Lyra support.
I am currently using AI Mesh 1.0, but would like to upgrade all of this to 2.0 and dont see a Lyra MAP-AC2200 386 bios
Here's my network list and the AI mesh 2.0 versions I have found
1x GT-AC5300 (head unit) - wired backhaul - AI Mesh2.0 version 9.0.0.4.386.41994
1x RT-AC5300 - wired backhaul - AI Mesh2.0 version 9.0.0.4.386.41994
1x RT-AC86U - wired backhaul - AI Mesh2.0 version 3.0.0.4.386.42643
3x MAP-AC2200 (Lyra) - 1 wired backhaul, 2 wi-fi backhaul - AI Mesh2.0 version ?
ligeza
I sent you a PM with link to this files downloaded from 52asus.com on my google drive. If you want, you can download them, sent to another file hosting service and share them here.
DelBierzo
The Lyra MAP-AC2200 works perfect for me with this version of the firmware "FW 9.0.0.4.386.41615 RC2 (Aimesh 2.0)", since February, no faults, no problems.
paull79
@ligeza @DelBierzo can you explain why this firmware is never getting posted on the forum?
I am following the forum and been waiting since first beta of Aimesh 2.0 for support of Lyra Mini (MAP-AC1300), but all I see is people requesting it in PMs while firmware for all other supported routers is publicly available.
With that being said, I still have not gotten my hands on it so no matter what the answer to the above question is, I would still like someone to send it to me.
Thank you :)
ligeza
The firmware was posted on the 52asus.com, I don't know why it also didn't get posted on this forum, maybe there are some bugs or it's for Chinese market. I sent you link to this firmware. If you want you can upload it to a file hosting service and share it here.
TheStork
Do we know what the origin of this firmware is? Are we sure it is not some hacked ‘special edition’? It just seems a bit strange that it popped up in some forum months ago, but there is very little information on it.
Is it a genuine Asus beta, and is it still being actively developed towards a release version?
RMerlin
Asuswrt-Merlin dev
Yes, Lyra devices can be used as a Mesh node with a router running my firmware. I actually did quite a few tests that way using a Lyra Trio as a node to my RT-AX88U.
DelBierzo
As I have said before, it works perfect at least for me, I do not have or have had any problems. Asus RT-AX58U (FW Merlin 386_2_4) and Lyra MAP-AC2200 (FW 9.0.0.4.386.41615 RC2).
TheStork
Does anyone have the Lyra Mini (MAP-AC1300) version of this 386 beta firmware they could share? I’m tempted to try it, although am still wondering why the only place where these betas cropped up was 52asus.com, rather than there being more debate around the betas e.g. here.
ligeza
MAP-AC1300_9.0.0.4_386_41615-g7c2264e.trx
MAP-AC1750_9.0.0.4_386_41615-g7c2264e.trx
MAP-AC2200_9.0.0.4_386_41615-g7c2264e.trx
jswing
I've been waiting forever for the 386 base for Lyra voice (have two of them). Am going to try the link provided heretoday. Hopefully, Asus will release fully supported version soon (same goes with RT-AC5300 - i only see a beta version for this).
jswing
I cannot flash this version found in the links: Lyra 386 RC2 FW v9.0.0.4.386_41615-g7c2264e. It seems too small. Can someone send me the proper firmware file?
gatoo
Is there any new release of beta firmware for Lyra? on v.41615 2.4GHz has very poor performance.
David Sullivan
RMerlin, if my devices are all asus firmware, can I put merlin version on my GT-AC5300 without needing merlin on all of my AiMesh devices?
RMerlin
Asuswrt-Merlin dev
You can mix Asuswrt and Asuswrt-Merlin devices within an AiMesh network.
jj351
I see you now support the GT AX11000 (My main router). Is there any benefit to having nodes run your firmware as well? I have two AX92Us as nodes but see they still aren't supported yet.
And will you be supporting the AX92U in the future?
Thanks.
