Ka Hooli
Hi, I have a 100mbps/40mbps Fiber connection, and with it our ISP has provided an IPTV Set-Top (aka FetchTV) box for some Pay TV channels.
Under my previous router (Linksys E3000 with DD-WRT), I was able to make all traffic for a particular device a higher priority by using its MAC address.
I now have an Asus RT-AC66U with AsusWRT-Merlin 3.0.0.4.372.31 on it. I think I have set it up right, but wanted to confirm. So I have gone to Traffic Manager - QoS - User-defined QoS rules, and set it up like this...
The problem I am having is that my IPTV intermittently pauses for a second, so before I go back to my ISP, I just wanted to check that I have set my router up ok. When only watching one channel, it should only use 2mbps, but can use up to 6mbps when watching one channel, and recording two others. This is still a lot less then my 100mbps. Also, if it helps, all equipment around my TV is connected to a Cisco SG 100D-8 switch which is then connected to my router. All Cabling is pre-made Cat 6 cabling. The switch supports Jumbo Frames, should I also enable Jumbo Frames under LAN - Switch Control?
