Making hostname to work with openVPN
m33ts4k0z
Hello,
Ive created a vpn network using my AC88U as a oVPN server and everything is working find including it giving internet to all the connected clients.
The only issue that I have is making my domain to work. Here is an example:
I have my ftp listening to ftp.mydomain.com on port 21
This domain resolves to my local WAN IP and my router knows where to forward the port behind my NAT.
If I try to connect to this domain while I'm at home or while I'm at the office using an over-the-Internet connection everything works.
However if I'm outside and I try to connect to my VPN at home and then try to access my FTP using the same domain again then I get a conection refused error. However I can access my ftp using the internal 192.168.x.x address when I'm connected to the VPN. Any ideas?
Thanks in advance
