1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
May 23, 2018 RT-AC88U new firmware 384_20942 available
Discussion in 'ASUSWRT - Official' started by Gregory Phillips, May 21, 2018.
  1. Gregory Phillips
    Gregory Phillips Senior Member
    Mar 27, 2017
    369
    Wherever I want to be
    I'm currently on 384.20379 and my router is flashing that a new bios version is available but the router cannot contact the server to get it. When I check my product page the support page is not available so Asus is definitely adding a new bios version today so keep checking for it. I will update this with links and behavior when I am able to get it.:D
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. Sammy2
    Sammy2 Regular Contributor
    Mar 13, 2018
    115
    My RT-AC3100 is showing an available update too but the change log is not up nor is the portable installer on Asus' website. What gives? I've been wondering what is taking so long for this model to get a new f/w and am growing tired of stability problems and disconnects of my nodes and/or their clients. I'm about to roll a couple back to wireless bridges because some (CetonCorp Echo Windows Media Center Extenders) of my clients are real sensitive to changes in network state and need to be power cycled nearly every time I go to use them so they'll connect back to the host WMC PC which is unacceptable. Hopefully this f/w will roll out with a changelog and more importantly will fix this issue.
  4. Gregory Phillips
    Mar 27, 2017
    369
    I just checked and the support page is still down and the router cannot contact the update server so no update as of yet.:(
  5. fax
    fax Senior Member
    Feb 9, 2015
    306
    The firmware version number is however weird 3.0.0.4.948_20942. 948??!!
    Sent from Nokia 7 Plus with Tapatalk
  6. OzarkEdge
    OzarkEdge Senior Member
    Feb 14, 2018
    392
    USA
    Similar story here for the RT-AC86U... current 3.0.0.4.384_20648 with pending 3.0.0.4.984_20942 and no release notes... yet.
    OE
  7. mlippold
    mlippold Occasional Visitor
    Jan 13, 2016
    46
    Same thing on my RT-AC5300:
    Latest Version : 3.0.0.4.984_20942-ge38bead
  8. Gregory Phillips
    Mar 27, 2017
    369
    It seems like the last time they did this that the firmware didn't appear on the server until late in the day eastern time.
  9. Zvqra
    Zvqra New Around Here
    May 31, 2016
    8
    Version 3.0.0.4.384.20942 2018/05/21 45.88 MBytes
    ASUS RT-AC5300 Firmware version 3.0.0.4.384.20942
    - Improved system stability.
    - Improved AiMesh performance.
    - Fixed XSS vulnerability. Thanks to Yonghui Han of Fortinet's FortiGuard Labs.
    - Fixed CVE-2018-8877, CVE-2018-8878, CVE-2018-8879
    - Fixed plain text password vulnerability in lighttpd.
    - Modified Quick Internet Setup wizard process.
    - Main SSID and guest network can hide independently.
    - Fixed OpenVPN client authentication issues.
    - Fixed DDNS register bugs.
    - Administrator can asisgn specific WAN interface to register DDNS in dual wan load balance mode.
    - GUI can show current control channel when enabled Smart connect.
    - Fixed OpenVPN client DNS related issues.
    For now only available under Windows 7 64Bit download.
  10. Gregory Phillips
    Mar 27, 2017
    369
    I keep checking and nothing posted on the product support page yet as I still cannot access it and the router still says it cannot connect to the server.
  11. Ronald Schwerer
    Ronald Schwerer Regular Contributor
    Jan 8, 2017
    173
    And you want to be the pioneer to install it first?
    As the saying goes - you can always spot the pioneers...they're the ones with arrows in their backs.
  12. Gregory Phillips
    Mar 27, 2017
    369
    Well if it doesn't work so well I'll roll back no harm done.:D
  13. fax
    fax Senior Member
    Feb 9, 2015
    306
    Yeah, within the router is wrongly indexed, so unless someone fix the wrong number we only have the Asus firmware download site as source. :(
  14. Gregory Phillips
    Mar 27, 2017
    369
  15. ColinTaylor
    ColinTaylor Part of the Furniture
    Mar 31, 2014
    5,469
    UK
    "Placeholder title: May 21, 2018 RT-AC88U new bios being released today"
    It's a firmware not a BIOS.;)
    ScyldScefing, Gitsum and Kal-EL like this.
  16. Gregory Phillips
    Mar 27, 2017
    369
    I see what you mean when the router searches the update server it gives the new version number but can't access it.
  17. Gregory Phillips
    Mar 27, 2017
    369
    Now the router yellow exclamation mark is off and when I use the router upgrade check it states that I have the latest version so something has changed.
  18. sanke1
    sanke1 Regular Contributor
    Jan 11, 2014
    88
    IN
    For me it says The router's current firmware is the latest version.
    This anticipation thread needs to be deleted. Create a new thread when any firmware actually releases :)
    Ronald Schwerer likes this.
  19. Sammy2
    Mar 13, 2018
    115
    I have the flashing yellow exclamation point but in the Firmware Upgrade page it says it is up to date. Should I upgrade from the flashing yellow exclamation point? I usually don't do that but manually go to the Firmware Upgrade Page. Does clicking the yellow exclamation point just take you to this page so there will be no upgrade anyhow? I really like to read the change log before upgrading f/w but also want better stability on my nodes so may just jump in.
    TIA
  20. fax
    fax Senior Member
    Feb 9, 2015
    306
    It will not work anyway ;)
    Sammy2 likes this.
  21. Grisu
    Grisu Senior Member
    Aug 28, 2014
    356
