Ripshod
I'm only posting this in case the current alpha makes it to release.
syslog-ng is failing to load/run. Symptoms include the sidebar not loading on the System Log>General tab, only the System Messages visible, configurations in /opt/etc/syslog-ng.d not loading. Feels like a stall-out.
Everything in cli looks fine:
Re-installing doesn't fix.
Please select an option: s
checking syslog-ng daemon ... alive.
syslog.log default location ... /jffs/syslog.log
... & agrees with config file ... okay!
checking system for necessary scribe hooks ...
checking S01syslog-ng ... present.
checking service-event ... present.
checking post-mount ... present.
checking unmount ... present.
checking logrotate cron job ... present.
checking directory links ... present.
checking syslog-ng configuration ...
syslog-ng.conf version check ... in sync. (4.7)
syslog-ng.conf syntax check ... okay!
scribe installed version: v3.2_1 (master)
scribe GitHub version: v3.2_1 (master)
scribe is up to date!
Please select an option: rl
reloading syslog-ng.conf ... Config reload successful
Restarting uiScribe ...Mounting WebUI page for uiScribe
Mounted uiScribe WebUI page as Main_LogStatus_Content.asp
Press [Enter] to continue:
