Media Server faster then the USB 3.0 mount....
Speedy1205
Hi Guys,
not sure if someone saw the issue before. I have a USB 3.0 Disk connected to the USB 3.0 Port. When I restart the router then the Media Server (dlna) is starting faster then the Mount of the DISK and because of this, the disk gets mounted to a different location (ESB-CM(1) ) which makes thinks difficult :-( Any Ideas what could happened ?
I believe that the DLNA Server is writing the database before the mount.... is there a way to stop and start the Media Server manually ?
Hi Guys,
That only happens to me if the router is not rebooted properly. by that I mean rebooted using the power button no the GUI.
It is a known problem..
It happens to me, too.
Also reeboting through interface.
I have to disable DLNA, reboot, Re-enable DLNA.
Don't know why it isn't fixed yet.. it should be very very simple.. just a delay in DLNA start..
Merlin.. I know you don't like messing up with Asus USB functions.. but it would be great if you fix that..
If you want you can use this script which I use. In the GUI I just left Media Server disabled and I run the script which will not screw up my mount points:
#!/bin/bash
sleep 2m
datestr=$(date +%Y%m%d_%H%M%S)
ps=/jffs/ps
# date used to add to the log file (append) so all the logs will be collected with the date and time no log overwriting....
if grep ESB-TB /etc/mtab &>/dev/null; then
echo $datestr "USB disk for ESB-TB is mounted for media server operation" >> /tmp/syslog.log
else exit
fi
/bin/ps > $ps
if
grep minidlna /jffs/ps &>/dev/null; then
echo $datestr "minidlna server is already started and is not using its new configuration" >> /tmp/syslog.log
else
/usr/sbin/minidlna -f /tmp/mnt/ESB-TB/TB-DISK/Scripts/minidlna.conf -R
fi
rm $ps
I just added this in the /jffs/script/post-mount
like this: sh /mnt/ESB-TB/TB-DISK/Scripts/mini_dlna_start.sh &
this works fine now.... If you have some question....
Interesting..
#!/bin/bash
sleep 2m
ps=/jffs/ps
else exit
fi
/bin/ps > $ps
if
else
fi
rm $ps
I have not really understand how to use it..
Do I have to name it post.mount and put in scripts?
Than I only have to replace HDD mount point with mine?
I don't understand this "sh /mnt/ESB-TB/TB-DISK/Scripts/mini_dlna_start.sh &"
ok here a bit more details:
Maybe you have the file or you need to create it:
create the file:
touch /jffs/scripts/post-mount
will create the file when it isn't there yet.
the content of my file is:
#!/bin/sh
sleep 5
[B]sh /mnt/ESB-TB/TB-DISK/Scripts/mini_dlna_start.sh &[/B]
So well that's just telling that the script should wait 5 Minutes and than execute the the script for DLNA where you have to change the mount point for you script location.
You need to change this:
you have to replace the ESB-TB with the mount point your USB disk uses
and
where you need to change the path.
If you want you also can just copy paste the complete text into the /jffs/scripts/post-mount which will work also. I just have mine in a different location that's why I add there just to execute the script with the location.
Its up 2 you.
