Unfortunately , it's asus server thats having issues....Hopefully someone over there will wake up and fix it.....It's been about 5 days or so that it has been that way...
lol....
If someone would rar their "asusware" folder , that already has media server installed, and upload it , we could just apply the folder to our usb....
Unfortunately , nobody seems to be willing.....
If someone would, that would be great!
Thanks to whoever might take the time!
here is a fix for the issue
1 try installing download master or media server on your router, it will fail but it will create an asusware folder on your usb device.
2. download this file
https://dl.dropbox.com/u/13605628/optware.asus
and copy it to usb driver:\asusware\lib\ipkg\lists\optware.asus via samba (network share)
or you feel a bit geek telnet to your router - you must have it enabled from advanced - administration
and paste this into the cli:
wget http://dl.dropbox.com/u/13605628/optware.asus -O /opt/lib/ipkg/lists/optware.asus
3. reboot router.
after your router boots up, try to install again the media sever / download master. should work now. enjoy
Hi baadnewz !
I tried this link, but i did not found any file to download ... just a page which describes several files ... but not the files. Any tip ?
Thanks !
you didn't found a file because the browser reads the file. either you copy the text from there into a file and save it as optware.asus either you do the telnet version and no headaches
sure if you've read 2 posts above yours you would had the answer already
This problem is back for AC68U Router for Firmware version 3.0.0.4.384.32799 (previous from latest version). DownloadMaster also has been removed from Firmware version 3.0.0.4.384_45149 (latest to date).
| Thread starter | Title | Forum | Replies | Date |
| T | Running Asus DSL-N14U as AP, network storage and print server | ASUS N Routers & Adapters | 11 |
Welcome To SNBForums
