Merlin 384.18
Tommy Grace
Hey guys
Anybody else using this yet? Seems stable but on mine it no longer measure upload bandwidth properly. Might not be Merlin, might be the stock code etc. It also doesn't show the units on the scales. Download seems to work fine. Anybody else have the same issue?
DarkKnight75
Hey guys
Yep..issue is with stock code as mine exhibiting same behavior on AC86U
Makaveli
Works fine for me.
  • Like
Reactions: a5m
Makaveli
Mine also works..he's referring to no numbers appearing on the scale where the lines are
The way his post is worded he seems to have two complains it not working and the scaling.
For me both work.
  • Like
Reactions: a5m
Tommy Grace
No i am having 2 issues. No numbers on the scale and it doesn't read the upload. Stays around 0.1Kb/s all the time. Must be a GUI thing as the iOS app works and measures the upload fine.
Makaveli
Makaveli
Not much to be honest. Other than changing the "Scale" and "Show by" parameters. I also disabled and re-enabled "Apps Analysis".
Any Reboots?
Also what about turning QOS on and off or vice versa.
netware5
netware5
Why not just advise instead of being arsey about it?
Sorry about your feeling. That was not my intention. But I do believe that it is much better to have all issues about 384.18 discussed in one single place.
Tommy Grace
Fair enough, maybe it’s the way I read it. I hadn’t seen the other thread before so happy for it to be moved.
netware5
@RMerlin can move it if decided feasible. BTW on my AX88U I have similar but not the same problem. The large "speedometer" (total upload) in the upper part of the page shows upload speeds correctly. But "by client" measurement below is totally wrong. Currently my file server is uploading torrent data with approximately 240 kB/s (1920 kbit/s), indicated by Transmission Remote GUI. The large "speedometer" shows 0.02 from 100 Mbit/s, which is almost correct. But the small one for my file server shows about 14 kbit/s, which is far from the truth. Currently the file server is the only device in my LAN that uploads significant amount of data. Really weird ....
Screenshot_2020-07-02 ASUS Wireless Router RT-AX88U - WAN LAN Bandwidth Monitor.png
Makaveli
I have a twitch stream open and my numbers are accurate.
