Merlin - Amule
ubuntolaio
Hi all,
I've installed Merlin 384.13. ( RTAC68U)
I'm using the 192.168.X.X:8081/downloadmaster/task.asp to download ed2k files, but I have to add each one manually. Is there a Webgui for amule ? I've tried on :4711 but it doesn't work
i have this
i'd like to have this
:):D
Is this a merlin bild or some unsupported fork of it?
Out of his control your going to have to ask Asus if you want that kind of GUI change, they have access to that part of the source code, also it will probably take up more of the routers resources slowing it down.
Download Master is completely separate from the firmware, and I have nothing to do with it.
I've found this file
@RT-AC68U-BFB0:/tmp/APPS/DM2/Config/dm2_amule# nano dm2_amule.conf
[WebServer]
Enabled=0
Password=
PasswordLow=
Port=4711
WebUPnPTCPPort=50001
UPnPWebServerEnabled=0
UseGzip=1
UseLowRightsUser=0
PageRefreshTime=120
Template=
Path=amuleweb
I've tried to enable webserver but nothing happens :(
