Merlin - FEATURE SUGGESTIONS
copperhead
Just purchased the Asus RT-AC86U but am debating going with the Asus GT-AC2900 to get the extra DFS Channels + 160 Mhz channel width. Those extras are likely to never be used but still nice to have options. With Merlin being in BETA for this GT router helps.
Anyway some feature suggestions:
  1. Search Bar -- a global search bar that when used can help you locate a particular item. Clicking on the item takes you to the tab / area
  2. Internet Traffic Gauge Setting -- At the moment the live gauge shows a dynamically changing horizontal bar. The size of the bar is worthless (Down = 1 MB/s shows a full gauge). Allow me to set my Internet Speed's actual upper limit (ie. max is 70 Mbps / 10 Mbps) this way the dynamic gauge is more meaningful
  3. Data Cap Limiter -- If one doesnt have an Unlimited plan they're sure to shoot past their monthly allotted data limit. Add some data usage limiter for a particular cycle. Think android data usage.
  4. VPN for Specific list of MACs or Ports
L&LD
Part of the Furniture
I don't believe there are any extra 'DFS' channels available on the GT model.
1., 2., 3., features get added very infrequently. Good suggestions, but not the focus of RMerlin's work.
4. Already there.
cooloutac
4. Already there.
I thought for 4. you could only specify ip address or ip range, but not macs or ports? You could though bind a mac with an ip which is what I do so it doesn't change.
Martineau
.....feature suggestions:
  • Data Cap Limiter -- If one doesnt have an Unlimited plan they're sure to shoot past their monthly allotted data limit. Add some data usage limiter for a particular cycle. Think android data usage.
  • VPN for Specific list of MACs or Ports
Using scripts, both of the above can be implemented.
