Merlin Firmware - Couple of questions.
TomT
Hi
New AC98U user, first thing I've done is load Merlins firmware.
Router is reporting the version as 3.0.0.4.374.43_2 (merlin build)
Is that the latest version ?
The zip file was called : RT-AC68U_3.0.0.4_374.43_2.zip
Under LAN -> DHCP Server I've enabled the DHCP server with a range of 10.10.0.30 - 10.10.0.50
In 'Manually Assigned IP around the DHCP list (Max Limit : 128)' I've entered about a dozen MAC and IP Addresses and named them. None of the addresses are in the DHCP Range. eg they are all lower than 10.10.0.30
When looking at Network Map / Devices most devices show the name I've assigned them, but a few (3) show as there MAC Address.
How do I get them all to show as the name I've assigned them ?
Thanks :D
:D As soon as I post this and refresh my router screen the names are appearing !
Well at least thats sorted.
Can some one advise if I have the latest firmware.
I think you meant to say RT-AC68U not 98 and yes 374.43_2 is the latest Merlin build firmware for the AC68U.
