Merlin firmware for AXE7800?
dragbug
As the title asks, is there going to be a Merlin firmware for the AXE7800? I see ones for the AXE16000 and AXE11000. Thank you.
Unlikely. This is not a high-end model, not very popular, none of the similar hardware models have support. This router is fancier looking version of RT-AX58U V2 hardware with one extra 2-stream 6E radio. Not sure why it even exists in this configuration. The Wi-Fi 6E radio with better chances for 160MHz wide channel doesn't support 160MHz and the Wi-Fi 6 radio with lesser chances for 160MHz wide channel does. Marketing, no much practical use.
Thank you. I was going to get the AX11000 or AXE11000 but went with this cheaper model based on some reviews. Guess I should have stuck with my original plan.
For about the same money better look at more popular around GT-AX6000 or RT-AX88U Pro. For home use you don't really need 3-band router and Wi-Fi 6E client support is very limited. There is no futureproofing with AIO home routers. Get what you need now, replace when you need something better.
From the 3rd post in the Asus-Merlin subforum's [FAQ] READ ME FIRST before posting a question sticky/tacked post:
Q: Will you add support for model XYZ?
A: The decision whether or not to support a new model depend on a long list of factors, which may evolve over time. Right now:
- It needs to be Broadcom-based
- It needs to be widely available (not just in two or three countries)
- It needs to have high-end hardware so I don't have to fight with lack of flash or RAM
- It needs to receive frequent enough GPLs so I won't have to regularly skip it due to the GPL being outdated
- I need to have one
- I need to have the time to try supporting it
- I need to have the motivation to try supporting it
Each new model requires its own dedicated support. That means every time I work on a new firmware release, I have to work on each separate model, and I need GPL releases from Asus for each individual model, and I need to merge each of them separately. So that means if I support 10 different routers, then I need to merge in the content of 10 different GPL releases, and these need to be close enough to one another to still be compatible. The more models I support, the harder this is to accomplish, therefore I am VERY conservative regarding adding any new model.
So don't ask if/when a new model will be supported. I cannot speculate about future model support, and until I have working support for a model, I cannot answer that question.
From the Asus-Merlin Wiki FAQ...
Q: Will you support router "RT-xXX" from Asus?
A: Most likely not. Without having an actual router to test with, building a firmware that people would flash without me having at least confirmed it can be flashed at all would be far too risky.
I bought this router because it was recommended by Wirecutter, It's frustrating that it's not considered popular enough to warrant Merlin support.
Not popular for many reasons:
- Wi-Fi 6E was never popular in first place, limited client support
- It's an entry-level hardware similar to RT-AX58U V2 + one extra radio
- It has weaker 2-stream 2.4GHz and 6GHz radios, built in BCM6756 SoC
- It's way overpriced for what it is, similar Archer AXE75 is about $100 less
- Firmware limited to Asuswrt 4.0, won't be getting Asuswrt 5.0 upgrade
- Interested in Asuswrt-Merlin firmware folks know it has no support
Buy routers recommended on SNB Forums instead.
