Merlin FW 378.54.1
pinkfloyd1173
So I updated to Merlin's new FW 378.54.1 today in the mornng. Now QOS does not work at all???
I have TW internet and my speeds are 320 down 25 up, if I enable QOS I get 20 down 19 up??
I did a hard reset and updated the new merlin FW, the FW that I use to have was 378.5134.
Mr Merlin did you mess around with the QOS feature with this new FW that you just put out???
Without QOS it works fine but as soon as I enable it everything starts to act up, FW 378.5134 worked fine with QOS enabled?
Anybody else having this issue with the new Merlin FW??
Thank you
Thank you
Make sure you didn't confuse bits and bytes when entering your connection speed on the QOS page.
I haven't made any change to QoS, and it's working fine for me with my 30/10 Mbits connection.
Check your QOS settings. I've found that on doing hard reset the AC 87U defaults to give GAMING the priority.
Thank you
Hey Mr. Merlin, triple checked everything and still cant get QOS to work with your new FW??? I reverted back to 378.5134, and its working perfectly, with QOS enabled 322 down and 25 up. Dont know what it could be but even tried the new beta thats on the asus wsebsite and that was giving me a few issues too, very weird, will stick with this until ASUS releases a new FW not a beta.
I second this. Experiencing the same issue with 378.54.1 on ac68u. Reverting back to 378.54
P.s hard reset done on 378.54.1 but to no avail.
I have this FW on both N66U and AC68U, both running smooth, the only question I have is how to keep the ad blocker in Ai Protection ? I had no issues with it and it was working very fine for me. tnx
