Yes, possible (I dont know exactly how, but it involves setting iptables), but you're posting in the wrong sub-forum, you should post it here to get your answer:
http://forums.smallnetbuilder.com/forumdisplay.php?f=42
Hi
Can you set up a VPN connection with the router (AC87U) and allow only some clients to connect to the VPN and leaving all other clients to connect to standard connection (no VPN)
Is this duable?
Just spent the last few nights getting this to work on my RT-N66U.
There is plenty of posts on forum to help you but I followed http://www.dondeg.com/vpn/tut3a.html
Dont know if this will work on your AC87U but worth a try...
Welcome To SNBForums
