Merlin upgrade AC3100
keef
Hello all. I have an Asus AT-AC3100 router and I updated the firmware to 386.1_0. It was successful except I cannot log into the gui. The network works fine, I can login the back end with Putty. I used SCMerlin to reboot the router however I still cannot log in the gui.
Has anyone else seem this or have any ideas.
thanks
UPDATE: It resolved itself after a 2nd reboot. I cannot seem to delete this message.
kImbo
I have the same problem and i am so new to this that i dont know what to do than just go back to factury settings.
First try ever with this and i feel like a fool :-(
kImbo
thanks
Diddent work for me - I just unplugged the power and started it again - is there a better way to reboot?
keef
Do not feel like a fool. I have done many Merlin firmware upgrades with zero problems. Something just went funny. Two router re-boots and all is well here. Unplug and plug in your router, that should do it (maybe twice if you still cannot login). I'm curious how you could reset the router to factory defaults if you cannot login to the GUI?
RMerlin
Asuswrt-Merlin dev
READ THE CHANGELOG, for crying out loud...
keef
Well, I rebooted from the backend, however unplugging the router would accomplish the same thing. I was just too lazy to go to the router, the SCMerlin way means I could keep my butt in my chair.
kImbo
Thanks for being nice.
I used the reset bottom on the back of the router.
kImbo
Perfect, thanks.
Is that the part where it says?
Some users upgrading might have to go through some
database maintenance on first boot, which means the
router might be slower or have a non-responsive webui
for a while.
This can take anywhere from 5 minutes up to an hour,
depending on your model, just give it time to complete
the process.
Thanks for helping.
keef
for a while.
the process.
Thanks for helping
Yes, it is. Just wait a few minutes and all will be well. I rushed it and to my peril I did not read the changlog-ng.txt file.
kImbo
Solved: I reinstalled the Asus firmware after a reset to factory settings and then installed the Merlin - upgrade.
This time i could login right away.
Thanks for helping.
PS: Is there a setting to extend the wifi to handle 1 gb data.
Now i get around 300 mgbits on wifi and around 900 mgbits on cabel.
Update: Found that its not possebly - Thanks - Enjoy you day.
