MikroTik Router recommendation
yoniyon
Hey everyone,
My office is in need of a Mikrotik router so I wanted to ask the experts.
The requirements:
1. the router should be able to connect to 120 devices which will send requests/accept requests all day long(through the router)
2. connected to a switch which will be connected another switch's and then to the 120 devices.
3. connected to a computer
4. be able to accept minimum 200 m/b connection
5. handle good static IP.
6. Not expensive but Good.
router -> switch ->switch's -> 120 devices
router -> computer
Edit:
Also would love a recommendation for a 1 to 8 switch .
Thanks Alot!
Yon.
How about a Cisco small business router? They are very easy to configure as they have a GUI. And for the best switch is to use a Cisco small business layer 3 switch. The 2 together is a great combo.
Check out the MikroTik RB4011.
If it needs to be Mikrotik, i would recommend RB3011 or RB4011. Both have plenty of juice for what you are asking.
